Thread: headlights
    Jun 2009
    North East
    Default headlights
    does anyone know if fitting 100 watt lamps will help out the dipped beam problem? (i know they ere not road legal)
    HID too expensive &time consuming for me, trying to decide between osram night breakers which have been recommended on here and 100w lamps.
    advice will be appreciated, thanks
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    100w apart from being illegal, will melt all wiring dude
    dont do it
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    You have tried Duncan's mod to raise the supidly low setting? Do that, then fit decent bulbs.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Technically, you could fit 100w bulbs and run them through a relay so the wiring is protected.
    However, wattage isn't the be all and end all. Light output is much more important (lumens/lux) and a IIRC, a NB puts out a better light than any 100w bulb
    The latest NB's (NB plus) claim to have a longer life span so they might be worth a looksee http://cgi.ebay.co.uk/OSRAM-NIGHTBRE...item588b429179. I've also tried Philips Xtreme in another car but i keep going back to NB's.
    Oct 2007
    Shropshire
    You can run the 100w bulbs fine on the standard wiring, I did it for months and it was fine. However as GTR said wattage is not everything. A high output 55w one can be as good.
    TBH I spent a lot of money and effort on higher power bulbs, higher output bulbs etc and they are better, but if you want a real upgrade just go HID. I like you went against it for ages because of cost/effort, but in the end its worth it. IMO the others are a waste of time. It took me three years before I tried HID's and they are really good.
    13 Post(s)
    Quote Originally Posted by gtr1000 View Post
    But the extra heat from the bulb could end up melting the headlight lenses and reflectors.
    HIDs is the best way to go.
    Jun 2009
    North East
    many thanks for all your help.
    grumpy1954 , can i ask for details of duncans mods to raise the low setting - not sure waht you mean here?
    thanks simon
    just searched Duncan's posts and it's not distance i'm struggling with it's the illuminationn on the road, they go far enough, i just find them the dullest headlights i've ever owned.
    thanks
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Adjust the headlight adjusting screws on the headlamp, located under the bonnet on the headlamps them selves. Turn the vertical adjustment bolt 1 full turn to raise the beam higher. Then do the same for the other side.
    Perhaps draw a line on the bolt before you turn it as to use a a guide.
    Its only HIDS that will improve the light output. I tried different bulbs first, but then gave in and bought hids.
    Wow what a difference, you wont regret it.
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    as been said .your wasting your time and money on bulbs ...just get the HIDS fitted.
  1. L@@k what I've done with my headlights !!
    By Lakom_2006 in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 07:43
  2. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
