Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Defrosting the washer bottle?
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    Default Defrosting the washer bottle?
    Evening.
    Now we all know about frozen pipes and jets, that's fine. My problem is the washer bottle is just made of ice. It's supposed to be -16 here tonight. What would the best way of defrosting the bottle be? I've run out of idea now. Tried leaving it running on the drive for half an hour hoping the static heat in the engine bay would do it but nope, got a dribble then nothing.
    I'm stumped now apart from taking the bumper off and using a hair dryer.
    Cheers.
    Regular Member MRLUBBERLUBBER's Avatar
    North Lincs
    Just the question i was going to ask 'cos i've got exactly the same problem. HELP!!!
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    No easy way.
    Would need to pull the arch liner back and get a hair-dryer on it.
    Feb 2010
    liverpool
    if you do get it defrosted , empty it out and fill with screen wash 'neet'
    Regular Member Handyandy-UK's Avatar
    Mar 2009
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Not a lot you can really do given the location of the tank. Direct heat is not a good idea as well as being almost impossible. Indirect or general area heat from a hot engine will take rather a long time given the ambient temperatures and seperated distance between engine and tank.
    Use of an additional 'antifreeze' is about the only practical answer. The trick is finding a fluid with a freezing point lower than about -30c that does not affect any of the plastics in the tank/motor/hoses/jets. Cheap vodka possibly, meths, kero .... the choice and mix is down to the user, but check carefully first !!
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    not sure it would work but do you have fog lights its right next to them! or if you top it up with screen wash would it thaw it out! you are sure its frozen and not the filter blocked if you pull back the arch liner pull out the motor and there is a small black filter that gets blocked just pull it out and give it a clean
    Feb 2007
    North west
    park it somewhere hot and sunny for a few days.
    North Lincs
    It sound like basically we all need to wait for summer to arrive, next October apparently!
    Mar 2009
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by MRLUBBERLUBBER View Post
    I shudder to think how long it will take to thaw this lot out completely .... here in Shropshire it's currently -12c outside. Sod a white christmas... I for one am deffo solar powered !
    Jan 2009
    WGAF#5
    only ambient heat sufficient enough to thaw the bottle then add enough concentrate screnwash to ensure that its not going to refreeze
    thats the only way your going to get them working again
  1. washer bottle ?
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2012, 23:13
  2. washer bottle
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 18:08
  3. Washer bottle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:33
  4. Washer bottle cap
    By mreeve99 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2009, 20:09
