Results 1 to 10 of 11
Thread: Windscreen Washers
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Windscreen Washers
    Anyones frozen yet? Been minus double figures for the better part of 2 weeks now and mine still work fine and have done the whole time.
    Insignia jets with straight screenwash concentrate, either Holts or Motoquip stuff.
    Got the same in the work Crafter and its been frozen the whole time but am putting that down to poor design.
    East Midlands
    I have heated jets mate,what a waste of time they are,well they are arnt they,for the simple reason thay don't shockin work do they.
    Tain - Easter Ross
    Used to have them and swapped for the Insignia jets
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I found mine (Insignia jets) working fine up and down the M6/M1 last week..... the only problem came when some snow managed to settle in the larger void in front of the driver's side jet and rapidly became green snow while the passenger side continued to work fine.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Was up to my parents on Wednesday, frozen jets even with 100% straight concentrate screen wash, I guess the wind chill was down to -20 on the way up the M90. Think i'll pick up heated jets soon.
    Regular Member Jezzy's Avatar
    S.E
    There's a whole thread on this subject already:
    http://www.vectra-c.com/forum/showthread.php?t=123507
    Regular Member Dazzy2006's Avatar
    Notts
    Mine haven't worked for the past 3 days, i eventually removed both jets and the piping but the water is just slowly trickling out.I even emptied the water bottle and refilled it with hot water but still no luck
    Looks like i'll have to replace the motor and hopefully that will fix it
    Aug 2010
    Leeds
    Thanks to this site and the top advice which was neat screenwash not mixed rubbish it now works at -18 and no problems.
    It really is that simple.
    Notts
    Quote Originally Posted by Bigtee View Post
    Mine has neat screenwash but still not working thats why i suspect the pump has had it
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Dazzy2006 View Post
    If you're still getting something out of them then there's a good bet it's just the little rubber filter (part of the rubber grommet the pump mounts into) that is gunked up. Pull the motor and grommet out and clean through both with warm water before you write off the motor.
  1. Windscreen Washers
    By Bloicy in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 22:42
  2. windscreen washers
    By bigsteve2255 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 23:08
  3. Windscreen Washers.......
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 16th December 2008, 23:25
  4. windscreen washers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 19:04
  5. Windscreen washers
    By T4M in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 23:33
