Results 1 to 10 of 11
Thread: Problem with onboard computer
    Dec 2010
    York
    Default Problem with onboard computer
    I have just recently bought a 57 plate 1.9CDTI, drives brilliant and i have no problems apart from one with my on board computer.
    I am working out the sat nav, bluetooth and stereo but when i press the BC button i only get a trip timer come up. I don't get the BC1 or BC2 in the top 2 slots of the menu i dont get anything apart from the timer. Is this something that can be sorted easy? I have tried to search but did not no what to search for
    Ian
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by ian124 View Post
    Ian
    If it's the same as my CDTi, press BC, use the left/right arrow buttons on the head unit to change from the trip timer, to other info
    Dec 2010
    York
    Thanks for the advise, if I press the left or right button it changes my radio station through the presets, if I press the up and down buttons it manually tunes my radio. Still nothing there apart from the timer
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    What spec iis your car? Does it have the 3 line BC?
    Regular Member Robsey's Avatar
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    If you had the TID (Triple Info Display), it should come back with "No Function"
    But for you-
    If you have MID (Multi Info Display), GID (Graphic Info Display), BID (Board Info Display) or CID (Colour Info Display), then it sounds like you have the wrong code index programmed into the Display.
    BC disabled = stopwatch only, and when you turn off the headunit, the date will come up.
    If BC is enabled, the you will get stop watch, plus BC1 and BC2.
    When the radio is turned off, the you should see Range and another fuel consuption figure..
    So,
    I believe that your BC is turned off...
    Sounds like a programming Job
    Dec 2010
    York
    Yeah thats right the date and time come up when its turned off. I dont see the fuel consumption or range. Looks like ill have to go back to vauxhall
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Mine's the same - I have the CDC40 radio with DAB and was told originally that that was why I didn't have any BC other than the timer, but it sounds like you have a different radio?
    Some on here say it is re-programmable but my local dealer insists that it is not possible without some hardware change - bit odd as surely all the measuring bits are already there if they are the same ones used for engine management.
    Dec 2010
    York
    I have the CD70 Navi.
    As i have not had the car for more than a week would i be able to take this back to the dealer I bought it from and get it fixed under warranty
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    No as it's not a fault it's an optional extra, You could ask them to enable BC but they could charge you.
    Irmscher Insignia CDTI 130
    May 2007
    Norway
    And you will probably have to install the Washfluid-level sensor as well (if not yet there in the tank) when enabling the BoardComputer. Otherwise you be stuck with the WashFluid-level warning......
  1. Possible to upgrade CIM / Onboard computer
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 09:31
  2. CD70 Onboard Computer??
    By KeeronMac in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 19:25
  3. Onboard computer....MPG
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 07:32
  4. Vectra OnBoard Computer
    By Marko Peltonen in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 22:17
  5. Quick One, Onboard Computer
    By heaton_uk in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 13:00
washer fluid onboard vectra
My on board computer in my vectra is jammed on timer how do I fix this
vectra c computer no function
vectra c fuel bc1 bc2 not working
vectra c trip computer not working
astra cd 70 goes to range when turned off site:www.vectra-c.com
