Thread: Fault Code P1109
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default Fault Code P1109
    Can anyone please tell me what the fault is as this has come up on my code reader tool, my car is a diesel 1.9 and will not start.
    This is the only fault that has come up any help will be great, thanks.
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    Think it is an o2 Sensor according to my OBD-II Code reader APP on the Iphone
    O2 Sensor Voltage too low/Air leak or the Sensor is messing around
    Nov 2009
    colchester
    The booklet that came with my reader does not have the code listed!!! If its an 02 sensor i would be pleased at least it would be a simple job to replace it. But would this prevent the engine from starting?
    Jul 2009
    The Rift, Cardiff
    The O2 sensor is only picking up the fault, its unlikely to be the actual fault. Most likely to be an air leak somewhere.
    Regular Member Jezzy's Avatar
    S.E
    P1109 on my lists comes up as either:
    Intake Air Temperature (IAT) - B Sensor Intermittent
    or
    Secondary Port Throttle System
    Nov 2009
    colchester
    Just been out and the swirl bar has come off and laying on its side how can i fix this its hard to reach it with fingers
    Sep 2009
    Glasgow
    metal coat hanger, then use a chopstick and a long screwdriver to put back onto pegs, there is a hole in middle of bar, force chopstick in and line up with pegs and push down with screwdriver, simples 5 min work.
  1. P1109 Error Code
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:49
  2. 1.9 cdti 150 Fault: P1109 B SENSOR
    By SamT in forum Engine & Drivetrain
    Last Post: 22nd February 2012, 15:27
  3. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  4. Fault Code P1109
    By SSM in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 11:56
  5. P1109 fault code
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 17:35
p1109 vauxhall fault code
