My missus got stuck in the veccy tonight, and first one side went, then the other? I was wondering if, with all the reving trying to get out of the snow, that I have burned them out? Is it possible to do this?
Did she start the car with them switched on? I find that if you turn the engine over with then switched on they throw a fit and don't work.
Yes, the car stalled several times trying to get out of the snow......how much are the replacement bulbs?
Wise advice as they do throw a wobbly if they get constant re-start's hence why it is never wise to fit them in main beam units.
It may be worth letting them settle as it is a toss up between the ballasts and the bulbs as to which will have given up the ghost.
I always start, or re-start car 1st...
On a couple of occasions one has not lit, or the warning light comes on. and no amount of switching the light switch on/off solves it...
Engine off, re-start then hit the HID's and all is well. Try it...
indeed the one time that mine failed on the old signum ... they restarted after about 20 minutes - so try again they may now be ok![]()
How is it now Pete, if it is indeed the problem mentioned above they should have sorted themselves by now.
Wierd? tried them again tonight when I got home, and they are now working fine? very odd?
Mine does the same
