Results 1 to 10 of 19
Thread: Flickering HID's....:(
    Derbyshire
    Default Flickering HID's....:(
    Just fitted some HID's to the motor, some cheap Chinese make (There could be my problem!) And there flickering, which then eventually leads to them going off.
    I dont have the bulb error when they flicker, but do have it when they go off.
    Any way to stop this flickering at all?!
    All help appreciated...!
    Blantyre
    Did you get cancellors mate
    Derbyshire
    hi mate,
    I didnt no, just buying a set off ebay though, will these do the trick?
    http://cgi.ebay.co.uk/BULB-WARNING-A...item3cb388572e
    Just found a very old thread on here though saying he took his cancellors off & it solved his problem! well confused!
    Thanks for the quick response by the way
    liverpool
    mine flicker at start but then go ok after about a minute
    i just thought they where warming up lol
    although previous kits on other cars didnt do this
    Derbyshire
    Yeah this does it all the time though, then they go out!
    Ordered the cancellors see if they help!?
    Blantyre
    They should helpmate , you have a facelift
    Derbyshire
    ha i certainly do fella, how do you know! lol
    Derbyshire
    boys & girls.
    Got the cancellers and its stopped the flickering, but still got the error light on the dash.
    any ideas how i can get this off??
    stockport
    Exclamation
    I have fitted a new set of HID's 35/6000 from HID's Direct,as the cheap ones I had fitted from China,off eBay,worked fine but got really hot after about an hour.Well,they work fine,but the drivers side,and not the passenger side,kept flashing every 5/10 seconds when the car is open/ignition/side lights on etc,etc.I fitted a canceler in line,then another one as well,making two,but it made no difference,so,me thinks,ok I'll fit another canceler in line on the passenger side to see if that helps.Blow me if that one then didn't start flashing as well!!!,talk about "Blues and Two's"......If I drove around like that,in a Vectra.......I'd probably get nicked for impersonating a police officer knowing my luck.So,the question is,where do I go from here?.Does the alternative battery harness work or will I have to get VX to Tech II them,and if so is it expensive ?. FELIXX.
    Blantyre
    Quote Originally Posted by Davies20 View Post
    Causeits on your public profile
    boys & girls.
    Maybe have it reset if you know or if anyone on here can assist, i dont know if disconnecting the battery for the 30 mins will help, worth a go though
  1. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  2. Original HID's are flickering
    By netrootbg in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2011, 17:00
  3. led,s flickering
    By cranny 27 in forum Styling
    Last Post: 14th November 2009, 19:35
  4. flickering headlight
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 11:20
  5. Flickering HID'S
    By Bossybuggy in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2008, 22:29
