Results 1 to 10 of 28
Thread: HIDS again.....
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default HIDS again.....
    Just a couple of questions about hids
    1. I got my kit this morning 50w 6000k, one of the warning cancellor capacitors was missing, i have tried fitting them with and without it and both ways worked without strobing or flickering. Do i need then fitted or not, what would yo do?
    2. Both of the ballast boxes buzz when the lights are switched on is this normal or is something wrong with then?does this stop when the engine is running?
    Regular Member DarylAAS's Avatar
    South Shields
    The Buzz is normal mate.. it goes off when hids do.. but cant understand why you have only one canceller... unless the other one is a built in canceller like mine.. but then you should have 2 identical not mismatched...
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    I fitted my kit without the cancellor's, if your not getting any faults i would leave them off. It makes the installation a bit tidier and as far as i know the cancellors are only needed if the bulb warning or flickering occurs.
    May 2007
    Norwich
    Engine : 2.2 z22se
    There was only one in the box but the box had been opened which I thought was weird (not by the courier) is it ok to use them with out the canceller?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    If they work with out the cancellers youvr one of the lucky ones, and you do not needthem. However I would still contact the company you got them from and let them know one was missing.
    May 2007
    Norwich
    Engine : 2.2 z22se
    The company hid direct are now closed til the 4th jan so I will probably forget by then lol
    Hanging Heaton
    31 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Sounds about right for HIDS direct... Everyone moaning about non working cancellors, you must have got a kit they've just taken one out off to send as replacement...
    May 2007
    Norwich
    Engine : 2.2 z22se
    Yep that's what I thought, they closed today at 1 and the kit got delivered at 1.15 typical!
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Got my 50w 6000k kit this morning from them, had 2 cancellors in, no instructions though, looks all there
    Not tried em yet tho
    Hanging Heaton
    31 Post(s)
    Mileage : 140k
    Quote Originally Posted by tubby View Post
    If they work without them i wouldn't worry about it. seems 50/50 that you do or dont... I didn't test mine without as i thought i'd lose them if i didn't lol...
  1. Hids
    By barneytravolta in forum Styling
    Last Post: 6th August 2012, 18:23
  2. HIDS and MOT as of 04.02.12.
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 11:15
  3. hids (HELP!!!!!!!)
    By cookiejar31 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 20:20
  4. hids
    By cookiejar31 in forum Styling
    Last Post: 28th November 2009, 02:50
