Results 1 to 10 of 15
Thread: Water for coolant?
    berkshire
    Default Water for coolant?
    If doing a coolant change due to new stat been fitted (as per how2 section) can regular tap water be used or must it be distilled water like for batteries etc??? Someone said tap water was BAD due to additives etc building up? Many thanks from a poorley heated driver!
    your better off filling it with pre mixed antifreeze , about £5 for 5ltr at halford
    but there is no issue if you use tap water but wont be protected during the freezing temps
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by marktaylor View Post
    I think you're misunderstanding him, he's not asking if he should use water instead of coolant, he's asking can he use tap water for the 50% water constituent or does it need to be deionised water.
    Yes, you can use tap water. Mix it with coolant, 50% each. Vauxhall Long Life coolant is best (orange in colour) as it doesn't need to be changed regularly.
    Jul 2009
    The Rift, Cardiff
    the Vaux stuff is good quality and reasonably priced, £4.11 per litre or £16ish for 5 litres. 50/50 mix with tap water gives protection down to -38*c
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I have a condensing tumble dryer and use the water from that for batteries and coolant
    Also gets used in the steam iron but apparently I don't know what one is? Maybe HG will have a comment on this?
    EVERYWHERE
    Pink is also better than blue. It lasts longer (OK for five years rather than two).
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    VX Orange is a 5 yr change, and VX use standard tap water in the workshop for the 50/50 mix.
    EVERYWHERE
    Pink and Orange are also known as Red, just to confuse everyone.
    Middlesex
    Trim : SRI
    Mileage : 100k
    and remember never mix red (or pink / orange what ever we are calling it ) with Green / Blue..
    If you need to change the coolant colour - full coolant flush is needed..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    drinking water is upto standard on vauxhall coolant systems ...water only becomes a poroblem when it is poor as in spain and a few other places but uk water is fine...
  1. Water, Coolant & Heater Problem
    By tris_hill in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2011, 14:24
  2. water coolant temp sensor....
    By bertiecbx550 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 13:54
  3. Coolant Leak, Water Pump?
    By rsocon in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 21:46
  4. Advice/Info Needed - Losing Water/Coolant
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:20
  5. Water Pump/Coolant
    By barkzz in forum Engine & Drivetrain
    Last Post: 22nd September 2008, 22:31
