Results 1 to 3 of 3
Thread: ford Sony head unit into a vectra??
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Default ford Sony head unit into a vectra??
    is a double din unit fitted in a standard car the same as an aftermarket one?.......in the sense that it can be fitted to another with the correct wiring harnesses??
    for example. will this fit the vec providing i pick up the required harnesses?
    replies ASAP please
    thanks
    alex
    Regular Member gibbon7000's Avatar
    lincs
    Sorry cant help you, but will interested in the answer.
    Aug 2010
    whitley bay
    if i remember correctly the ford ones arent standard double din fronts they are slightly bigger so although the rear will be double din the front is bigger, a lot like the vectra ones etc
  1. sony head unit problems
    By pyper_honda in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2009, 01:00
  2. Sony CDX GT500 CD/MP3 Head Unit...
    By Dan_BlackSRi in forum General items for sale
    Last Post: 22nd April 2009, 10:02
  3. New Head Unit - Sony bt3600BTU, what do i need?
    By gekornro in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2008, 20:18
  4. sony head unit
    By david-bell in forum General items for sale
    Last Post: 17th May 2006, 18:59
ford sony into vauxhall
