Originally Posted by
m8internet
Given the smoke is a dark colour, the glow plugs may be struggling to fully detonate the diesel
I suggest you try this and compare
Turn the ignition in and wait for the glow plug light to go out
Switch the ignition back off then return it to on again so that the glow plug light shows again, but it should be very brief
Now start the engine
Allow the engine to idle for about 30 seconds before applying any revs
What is the outside temperature?
If the problem persists, inspect the glow plugs, ideally the one nearest the relay
If it is indeed at the end of its life, then replace all four
