Results 1 to 3 of 3
Thread: Positive -Negative camber?
    Dec 2010
    Bristol
    Default Positive -Negative camber?
    Does your car wheels have positive or negative camber allignment?
    liverpool
    it shouldnt have any really , but the rear do have slight negitive , even more so once lowered
    Regular Member Grimy's Avatar
    It should have around half a degree negative to help cornering, but depends on the manufacturers design setup to get the best results.
    here, found a quick artical for you:-
    Camber is the angle of the wheel relative to vertical, as viewed from the front or the rear of the car. If the wheel leans in towards the chassis, it has negative camber; if it leans away from the car, it has positive camber (see next page). The cornering force that a tire can develop is highly dependent on its angle relative to the road surface, and so wheel camber has a major effect on the road holding of a car. It's interesting to note that a tire develops its maximum cornering force at a small negative camber angle, typically around neg. 1/2 degree. This fact is due to the contribution of camber thrust, which is an additional lateral force generated by elastic deformation as the tread rubber pulls through the tire/road interface (the contact patch).
  1. Negative Camber
    By Hursty103 in forum Suspension, Wheels & Brakes
    Last Post: 19th October 2012, 14:53
  2. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  3. Negative Camber= Rear Tyre Wear
    By honigstrauss in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 10:26
  4. car feel's more positive
    By ditchp in forum Handling & Braking
    Last Post: 15th December 2007, 20:01
  5. Positive thinking...
    By BlueRob in forum General Chat
    Last Post: 24th November 2007, 00:12
