Hi All
Been having starting problems due to the EGR & following a flat battery episode this morning the DAB has stopped working
The station still comes up on the screen but i get no sound!
The CD still works fine!
Any ideas???
Hi All
Any ideas???
Sounds like you need a cold reset.
Un-do the battery again, for a couple of hours..
Then reconnect as usual.
This tends to solve about 90% of electrical glitches.
Failing that, check to see if your DAB is actually powering up - check fuses in the end of the dash (passenger side)
Usual ones to check are -
F1, F4, F7, F9, F10, F12, F17, F19 and F26.
Mine did that on the way into work yesterday too....
Worked fine later in the day![]()
Possible condensation in a connector or the head-unit...
Caused by the car warming up after being frozen up over night.
I know it plays havoc with my Nav CD...
It spits out the Nav CD, which is steamed up / damp.
A quick wipe down with a soft cloth and the Nav works again...
so yes to me - condensation...
battery has been disconnected a few times now & fuses checked but still no DAB!
can anyone give me another pointer for what to try next?
