Thread: brake light help needed
    Regular Member chrisg's Avatar
    Nov 2010
    hull
    Default brake light help needed
    hi,
    When i turn my lights on i can hear a buzzing for the back left of the car but it goes when i press the brake. I dont have any warnings on the dash.
    Thanks for any help
    Jul 2009
    The Rift, Cardiff
    Check the fuses and earth points in the boot for both light clusters to make sure there's a good connection.
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    Got exactly the same problem, any ideas on a fix please?
    Nov 2010
    Wolverhampton
    To be exact the buzzing is coming from one of two black boxes located in the boot fuse compartment. It only buzzes when the lights are on, and stops when you press the brake pedal, i've checked all the bulbs etc and all are fine.
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Sounds like a loose wire in the plug, causing little arcs,give your brake light wire a wiggle without using the brakes,see if it stops, if it does then just re-solder.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Upgrade What's Needed
    By sunbeam250bhp in forum Handling & Braking
    Last Post: 27th March 2009, 23:22
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Brake help needed
    By frazejax in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2008, 23:39
