Thread: Rear lights nightmare
    Regular Member Nav-Man's Avatar
    London
    rolleyes Rear lights nightmare
    Hi guys.
    Couple of month back a light came on my dash saying that I needed to change the left handside break light, last month I went to Halfords and bought a couple of their HD bulbs and replaced mine with those from Halfords, since then the light on the dash started saying that I now need to replace both break lights (left and right). I jiggled the bulbs a bit and the light on the dash went off, but a couple of hours later, it was on again.
    Is this a common thing? Is there a solution? Can anyone shed some "light"... on the problem???
    Thank you and have a very Happy Xmas everyone.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Change the bulbs.. if you dont do it now.. you soon have to anyway
    Regular Member badback's Avatar
    Runcorn
    Have you put the correct bulbs in? they are only single element, which shines brighter when brake pressed.
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Quote Originally Posted by kenp View Post
    hes right you know
    Regular Member Jezzy's Avatar
    S.E
    Corrosion on the electrical contacts that the bulb makes contact with. Take the bulbs out and scrape the contacts in the bulb holder.
    London
    I will try all the suggestions above. The bulbs currently on the car are new, so not sure why light on the dash still on. But will get new bulbs and see if it solves the problem.
    Quote Originally Posted by badback View Post
    badback, I'm not sure the ones I bought are single elements, will check, but got them according to code book at Halfords. Will post update later on.
    Thank you all for your help so far. Just got back from Midlands Exhaust, got a whole stainless steel dual exit system fitted and it just looks the part, well proud.
    preston
    bulbs on their way out will also chuck up error, even if they haven't died ( yet!!!)
    i'd clean my fittings then work through each bulb and replace if needed
    if bulbs seem ok and fittings are clean, try new bulbs to each fitting and then work back until you find the fitting / bulb causing harrassment
    6 Post(s)
    Quote Originally Posted by mparks8590 View Post
    He already has -
    Quote Originally Posted by Nav-Man View Post
    The bulbs currently on the car are new.
    preston
    bulbs can be faulty from new. alhough i'd suggest it would be bad luck to get more than one at a time
    still worth ( for the cost trying a new bulb ) and seeing if the problem dies
    are yours p21w
    kirriemuir
    i also had a bad connection to the block at the back of bulb holder
  1. Rear disc removal nightmare
    By Bigbaw in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2012, 15:08
  2. Nightmare trying to remove the rear caliper carrier bolts!!
    By richiem in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2011, 01:10
  3. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
