Results 1 to 10 of 24
Thread: Helpppppppppppppppppppppp
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default Helpppppppppppppppppppppp
    ive just went to move the car and i have found greenish snow below it, i think it smells of Diesel help what do i do
    PRESTON
    greenish????? sounds more like power steering fluid but some antifreeze can be green too. Check fluid levels see if they are low?
    Trim : SRI
    Mileage : 46000
    just got the bonnet up there is fuel around the top of the fuel filter i gave the car a few high revs before i went to move it, now the wifey says it looks between yellow and green could i just need a new filter its been 13k since i changed it
    PRESTON
    might just need the top tightening up, they have to be damn tight, at 13k i wouldn't say it needs a new filter. Probably fuel passing the seal, try tightening it first and check hoses are pushed in correctly.
    Trim : SRI
    Mileage : 46000
    thanks Barney i take it its safe to drive if its only the filter thats loose
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by rickeys16v View Post
    CDTI??
    No - if the fuel filter is leaking do not drive it.. They run a very high preasure and you could end up with diesel spraying all over the engine.
    PRESTON
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Hydraulic fluid from shock absorbers is also green. I had one drain completely overnight a while back. Worth checking.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by barney490 View Post
    In Ireland/NI the diesel is dyed red (normal agri red diesel) or green (taxed vehicle fuel).
    Trim : SRI
    Mileage : 46000
    i took it a drive before i read the dont drive post and there was a couple of drops on the ground after i stopped but before i went i wiped around the Deisel filter thing and it still seems dry... i dont think its the shock absorbers john as it was below the middle of the engine
