Results 1 to 10 of 23
Thread: Starting in the cold
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Default Starting in the cold
    Was so cold this morning -15 can petrol freeze took me a while to get it started, on turn over revs rose to 300rpm then cut out with the abs light after a few attempts got it started no warning lights and did a 20 mile drive with
    no problem any reason for this?
    Dec 2010
    Bristol
    Im not wise on petrol on wether it will freeze or not but surely if it had you wouldnt of gone 20 miles so prob something else!!
    Liverpool
    -12 here today, have a diesel and it started the worse I have ever known
    Regular Member VFR's Avatar
    North East
    Whatever your problem is it won't be because your petrol has frozen. The freezing point of petrol is around -60C. That should give you a wide enough margin for even the really cold days we have.
    Dec 2010
    Bristol
    Quote Originally Posted by VFR View Post
    jesus -60c
    that is cold
    Jul 2009
    Bucks
    Surely it must be the could then? Any other ideas why it would have trouble starting took about 5 attempts and had to give it a few revs to keep it going
    North East
    Cold does affect the battery quite badly, when you were starting it was it turning over at the the same speed as usual. I've seen it where a car is turning over at just below the point where it will catch and start but in warmer conditions it doesn't struggle at all. What sort of journey does you do, at this time of year most people will be using heated windows, fans full on, lights on etc much more than they would be otherwise and if they do a short journey the battery doesn't get a chance to fully recharge before their jorney is finished.
    Jul 2009
    Bucks
    It was a little slower than usual, and because I didn't give any revs it failed to start the first time, I did about 22 miles this morning took over an hour though due to conditions is the battery on it way out or just the could causing havoc it sounded a bit though until I gave it a revs
    North East
    Only sure way to know is to get it tested properly, if it's done properly they put a load tester on it and see what state they battery is in. Amongst other places Halfords do a free test, it's wherever you feel comfortable and trust who's doing it.
    Jul 2009
    Bucks
    Thanks mate, started up first time on the way home at -1, so no idea.
  1. cold starting problem
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2011, 16:54
  2. Diesel cold starting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 14:32
  3. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
  4. Rough starting from cold
    By TonyR999 in forum Engine & Drivetrain
    Last Post: 25th December 2006, 14:45
