Thread: Help Needed
    Regular Member Andie-100's Avatar
    Jul 2010
    Staffordshire
    Default Help Needed
    Hi guys. I have a 53 reg Edition 100 2.0T SRi.
    Driving home this morning i stopped at the lights and have had a light come on the bottom right hand of the dash. Looks a bit like an engine.
    Have done the pedal test and it gave me the code 0420. Checked all the posts and it shows that it is something to do with the emissions so assume its the lambda sensor. Does anyone know if there is 1 or 2 fitted to the car and if 2 which one it is likely to be and has it only happened as it was -11 this morning.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    The light is the Emissions light, normally there are 2 lambdas fitted, position 1 the one at the manifold, position 2 the one after the cat. Maybe the cat starting to fail. Code will disappear after 10 days, then if fault still there reappear. Maybe it just requires an "Italian" tune up IYKWIM?
    Ment to say "P0420 Catalyst Efficiency Above Threshold C-31"
    http://www.corsa-c.co.uk/forum/showt...ux-Fault-codes.....
    Jul 2010
    Staffordshire
    Yeah i know what you mean.
    I have a 23 mile trip to work every day and then back again and its all main roads and dont hang about
    So is it the one that i can see from the top of the engine?
    hull
    Had the same code come up on mine during heavy snow 3 weeks ago, didn't go out so i bought a code reader off ebay and cleared the codes, up to now 1 week later still hasn't reappeared so fingers crossed.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
