Thread: HID Fitting - Pre-Face
    Middlesbrough
    Default HID Fitting - Pre-Face
    I have just bought a 50w 6000k HID kit from HID-Direct and I understand everything apart from how the ballast/cancellor connects to the existing car wiring.
    Is it plug and play or does it require some wiring? I have done search and cant seem to find an answer to this.
    Any help is much appreciated
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    There are 2 wires with spade connectors on them, they plug in to the original VX wiring plug for the normal bulb in the headlight unit. Those wires run to the ballast, the ballast is then connected to the canceller, which in turn is connected to the HID bulb.
    Hanging Heaton
    27 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    The car wiring comes in one side, you fit the kit, HID's are on the other end... Pretty simple and the instructions will be in the kit...
    EDIT: Or you can just listen to the better articulated version above
    This is where i put my ballasts tho...
    http://www.vectra-c.com/forum/showth...llast+location
    Middlesbrough
    Thanks I figured it out as soon as I posted the thread lol
    Which way round do the spade connectors go into the plug
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 74000
    If you look at one of the black plastic plugs on the balasts im sure there is a + & - symbol on them, you'll need to put a multimeter over the original VX plug to get the + side, well thats how I did it.
    Hanging Heaton
    27 Post(s)
    Mileage : 140k
    Quote Originally Posted by Seery_SRI View Post
    If i remember right there colour coded, (kit)red goes in the black on the car, (kit)black goes in the brown on the car.
    But the instructions are pretty simple...
    You can see the spades here at the top, sticking out the rubber grommet.
    To be honest, the easiest way to think of these kits is like a balloon.
    The rubber grommet is where you tie the balloon and you have the 2 spades sticking out for the VX wiring and the HID bulb.
    Then the circumference of the balloon is the kit itself, round to the ballast, onto the cancellor and back to the grommet... If i make sense. read this now look back at the above pic and you should understand...
  1. how hard is it fitting genuine xenons onto pre face lift signum
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 23:27
  2. DIY Parrot fitting.... Pre face
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2010, 10:59
  3. face lift xp splitter fitting
    By mrroo in forum Styling
    Last Post: 6th April 2010, 19:04
  4. Irmscher face lift signum grille fitting
    By Lump in forum Styling
    Last Post: 11th October 2008, 17:37
  5. Face lift fitting silver indicator bulbs - Front
    By Andyuk911 in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2006, 14:39
