Results 1 to 10 of 27
Thread: Frozen diesel ?
    Jan 2010
    dunstable
    Default Frozen diesel ?
    Hi Guys,
    Any help appreciated !!
    i have a 2.0 Signum Diesel , Which i let run to 17 miles left in the tank! , With the bad weather i aborted a visit to fill up yesterday.
    This morning with the roads quieter i started the car , it ran for about a minute then stalled . It now urns over but will not start ! , I Have added a Gallon of diesel but the same result !
    The man from Greenflag thinks the diesel may be frozen ? ,
    Is this because it ran so low ? , I have let it get lower than this in the past..
    Please all help taken seriously.
    Thanks.
    north east
    frozen diesel the level has got low, at -9 it starts freezing / jelling.
    you should be able to get it going by putting the key in, move to position 2, remove key, insert key move to position 2, remove key and try start.
    If that doesnt work you will just have to wait for it to thaw and fill up, its always good to keep them over half a tank when snow is around
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Do foreign countries get sort of a different mix of diesel or an additive to stop this happening, when their climate is far colder than ours?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    never had that myself and had diesels for the last 15years. not to say that happens, I thought that fuel had addatives in nowadays, such like parafin to stop this?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by roswell View Post
    Can't see how that is gonna work?
    When were the leak off pipes done on the car? They could be letting air into the fuel system thus not getting the diesel into the pump.
    Also by letting the fuel get that low you may have choked the fuel filter with crap from the bottom of the tank
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    I thought all diesel in this country had the additives to stop it thickening up in cold weather?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It does and the Vec has a pre-heater in the filter housing
    Regular Member benny's Avatar
    Feb 2006
    dudley
    bassicly youve run out of diesel and need to bleed the fuel system the bad thing is your gonna have to crank the engine till it goes ...it will take a long time if the pipes and filter are all dry try putting even more fuel in then cranking it ...crank it for 10 secs then stoip then crank again for 10 secs keep doing this till it starts the older 2.0 can be a pain to start once the fuel tank has been run dry ....
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    although I would have thought the guy from greenflag may have already tried this
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yes we have "winter diesel" and "summer diesel".. quite normal here.. the gasstations change in mid/end october, and again mid/end march..
  1. Frozen Windows!!!
    By Johnsdutton in forum Comedy & Humour
    Last Post: 14th March 2012, 22:55
  2. frozen products
    By paul.sessions in forum Detailing and Car Care Discussion
    Last Post: 17th February 2012, 17:10
  3. Frozen windscreen
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 23:09
  4. frozen door
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:22
  5. My frozen backside!
    By simonali in forum Quick Photo Album
    Last Post: 16th March 2006, 00:13
