Thread: 2.2 direct wont start
    glasgow
    Default 2.2 direct wont start
    hi ,need help ,my car was running for about 5 mins drove for 5 mins then stopped engine for couple of mins then car wouldnt start at all ,electrics all seem to b ok ,engine tries to start but just will not catch.towed car back to house and it wouldnt bump start at all.its a 07 2.2i direct sri with 24000 on the clock.ive had no bother with the car at all till now no warnings .should there b a fault code?if so where?
    any help would be most greatfull thanks
    Jan 2010
    glasgow
    hi mate is it spining over slow or fast is it making any unusual noises wen turning over? ie are you 100% sure the timing chain is ok? is there a smell of fuel ie is it pumping fuel? when the car stoped did it make any noise just before it cut out as of codes it would need to be put on a tech 2 comp or op-com to get the codes off it mate where in glasgow are you?
    glasgow
    hey,car just seems to turn over normall but just does not catch,kind of whirring noise when its trying to turn over really hard to explain lol,no smell of fuel at all ,car was going like a dream before it happened no warning lights at all ,no noises before it stopped(the car didnt cut out i switched off engine to nip into shop)im in erskine
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would be checking if the chain aint jummped ..
    Jan 2010
    glasgow
    thats what im thinking maybe the chain has jumped or gone are you in the aa or rac mate if you are call em out they might give you a good idea if the chains gone
    glasgow
    Na aint got breakdown cover ,towed car to house no idea what to do with it,can the timing still go even tho the car wasnt really running?technically the
    Car wasnt running just woundnt start up
    Jan 2010
    Glasgow
    Quote Originally Posted by gordy07 View Post
    ...that's exactly how my chain went
    hope it's not bad news mate, i've got the same engine & the chain went at 31K
    glasgow
    WHat did u do barney?cars at house do u think vx dealer would come out and check it out ?
    Jan 2010
    Glasgow
    hi Gordy - i had breakdown cover so i got it towed to a local (non-Vx) garage.. i had to pay £50 to get the engine checked out and got told the bad news...
    hopefully your's isn't as bad as my car was... it cost approx £1700 to get it back on the road (and the fuel pump went 5weeks after that).
    Vauxhall were not interested and i've got a full service history with my car
    Jan 2010
    glasgow
    hi gordy i just sent you a pm with some 1s number but i dont know if he will come out to you or his garage is to far for you to travel to etc but it may be worth a shot failing that mate you could take the rocker cover off and turn the crank shaft and see if the chain moves at the top
  1. car wont start.
    By gstore in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 23:53
  2. Help car wont start. 2.2 dti
    By Middo in forum Engine & Drivetrain
    Last Post: 25th June 2012, 23:09
  3. 2.2 direct sri wont start!!
    By stephen2480 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2012, 10:56
  4. car wont start
    By neill in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:00
  5. help car wont start!!
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:51
vectra c 2.2 direct wont start
