Results 1 to 10 of 22
Thread: Freezing my nuts off, rubbish car!
    Newbury
    Default Freezing my nuts off, rubbish car!
    Yes I know it was -7C this morning, but whats the deal with driving (my most modern car I have owned - 1.8 52 Vec C) with no warmth on the temp gauge or through the blowers. I've checked the thermostat, coolant, blocked part of the radiator and for weeks the car has not warmed up at all.
    Any suggestions? (Apart from a different car).
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    you not been on for a while? it will be thermostat there must have been 50 threads about it in last 2 weeks! just out of curiosity how did you check yours
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    How did you check thermostat ? The only reason I thought my thermostat was faulty was because the temp use to drop to zero now and again even though I was getting heat from vents.
    But after changing it OMG it's hot hot hot and warms up within 10 mins now
    Irmscher Insignia CDTI 130
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by danno View Post
    Deffo thermostat
    If it's stuck open, the coolant will be circulating the radiator all the time. And air at -7 degrees will never allow it to warm up. HTH
    Newbury
    Brought a new thermostat (Thread below titled "spot the difference"), which I thought was the wrong one so put it all back together, then noticed with engine ticking over the gauge went up and I could feel warmth coming out the vents (this was the other day) and so once engine was warm, coolant level was topped up I went for a drive, and as soon as I got onto the road the temp gauge dropped and the vents blew cool air.
    So I can imagine a few people starting to use their heaters more and thus noticing no/reduced heat coming out and so to address the thermostat, but I did that and with the temp gauge going up minutes after putting the thermostat back but I just can't understand why the car suffers so badly. And even if the temp gauge shows a low temp reading, surely the heaters should still pump out hot air
    Newbury
    I think i'll put up for a bit then get around to fitting the new thermostat and stop my whinging in the hope the new one works tons better than the old one.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Deffo thermostat make sure you get air out of system too.
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    I did mine (1.8 SRI Petrol). Very easy - not expensive - now nice and toastie heater.
    Check out the How to by DasArab
    http://www.vectra-c.com/forum/showthread.php?t=122762
    On the radiator there is a drain tap on drivers side makes it very easy.
    See Sheepish, ChrisBilly and my comments on this page for Parts required & Tips...
    http://www.vectra-c.com/forum/showth...=122765&page=2
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My heater gets warm before the guage even moves
    2.2 DTi SRi (2002 C)
    Newbury
    Cheers MXT will take a butchers
  1. i am freezing
    By parkroad in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 19:43
  2. radio freezing
    By david12345 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2012, 13:45
  3. No, no, no, GT5 keeps freezing!!!
    By rushy in forum Games Room
    Last Post: 28th December 2010, 13:57
  4. Playstation freezing up?
    By Mark2.2 in forum Games Room
    Last Post: 15th May 2010, 20:47
  5. 1.8 won't heat up - Bl**dy freezing!
    By RCB in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2007, 03:13
