Thread: code p0101 & p0103
    leigh greater manchester
    Unhappy code p0101 & p0103
    can anyone help after 3 new maf sensors i am still getting codes p0101 & p0103 mass air flow problems defo no air leaks mapp done by ian at mpg he swears the map is sound codes come up after a long drive or after a thrash but not low rev driving
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    what engine have you got?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    its a 2.0t
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0103 Mass or Volume Air Flow Circuit High Input
    Quote Originally Posted by mart1977 View Post
    i have the z20net
    what could throw a maf code if the sen is fine no air leaks map ok am i looking at faulty 02, sens bad ecu, bad connection somewhere or am i missing somthing
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    boost sensor maybe, not sure if you can clean them, probably can with some circuit/connection cleaner or a chuck some isopropyl alcohol in plastic zip bag put in the sensor and shake it about then leave in there for 20 mins.. wait until its dripped dry throughly before you put if back on the engine. Incedentally you can clean your MAF with this as it normally sorts them and saves buying new ones.
    The boost sensor is otherwise none as the boost solenoid and also the 'Charge Air Bypass Valve', it seems to go and can cause a few issues with differing symptoms.. I am not saying this the definative fix but a replacement part only costs about £14 from or about £12 trade. part number is 55354158. Its not a stock item though so ring first and order one etc.
    Does the car drive normally, no loss of power or boost when loading the turbo? The MAF can throw an error even though it is not at fault, it can be over compensating for something else like the boost sensor or a mucky throttle body.
    Make sure your air filter is in good condition as well.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    i should add that errors codes will not clear straight away after changing a part, the codes clear after having driven a certain amount of miles or a certain amount of successive restarts without errors being detected. To clear the codes without a code reader you could just disconnect your battery for about 30 mins, be sure you know your radio code though in case it asks for it afterwards, some other settings go to default also like auto window close but these are easily sorted. Apologies if you already knew this bit, but thought it best to post just in case.
    Nov 2013
    Norfolk
    Vehicle : Vectra edition 100
    Trim : Edition 100
    Engine : 2.0 turbo
    Did u ever solve this problem I have the same problem and have tried allot of new part with no success
  1. help with code
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 13:43
  2. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  3. P0101 and P0234
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 7th May 2012, 06:10
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. Key Code
    By Blingbloh in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2008, 22:34
p0101 opel vectra
p0101 z20net
vectra 2.0t p0101
z20net p0101
p0101 opel signum
p0101 vectra c
opel vectra c 1.9 cdti 110kw p0101 kod
