Results 1 to 2 of 2
Thread: Starting on 3
    Full Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Default Starting on 3
    I have Sept 57 Veccy 1.9CDti would this have had the 3 injector plug change before delivery ??
    I do not remember the dealers telling me they had done the modification.
    Was this a recall item.
    As it is out of warranty what would Vx's position be on carry-out the upgrade???
    This only happens when it is very cold so could it be the glow plug rather than the Injector???
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    If your injector plugs are all blue,it has the newer wiring already,i think it was only early cdti's that had yellow plugs.
    I had my glow plugs changed at the dealers along with the service when i first bought the car in october,because i plugged it in and it came back with a glow plug error code,and mine still started slightly lumpy from cold,when it was cold just before and over christmas.
    So i bought a can of wynns diesel clean up to try,and it seemed to work for a while,so i thought.
    But infact i think it's the voltage given to the common rail from the alternator,and if you rev the engine a little after a few seconds from the first start,it will run fine again,until you start from cold again and repeat the proces again.
  1. Not Starting
    By mungo1985 in forum Engine & Drivetrain
    Last Post: 11th September 2012, 21:52
  2. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  3. bad starting
    By reg in forum Engine & Drivetrain
    Last Post: 20th April 2011, 09:01
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
