Thread: Cold weather causing spanner warning light to come on???
    Nov 2009
    newcastle upon tyne
    Default Cold weather causing spanner warning light to come on???
    Since the weather has dropped below 0,on start up the spanner warning light is staying on but after driving for a few minutes(not fully warmed up)it goes off.This isnt happening everytime but if i turn the car off then start up again it doesnt come back on?..The car doesnt drive any different,no lack of power,the only thing ive noticed is fuel economy is down......Anybody know whats going on here or had the same fault?
    Jan 2010
    Lisburn
    I have had nothing but trouble getting mine started/spanner light since the cold weather, albeit I think it highlighted something that I inherited/needing done anyway, the EGR valve etc... not sure if its "normal" but reading the forum, lots seem to be having similar trouble if not worse with the freezing temps/snow atm
    This my first year with a diesel, secondhand at that but all the same, they dont seem to like the cold half as much as petrol does
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by supersione View Post
    what engine ?
    if a Diesel its probably the glow plugs , mine did exactly the same till i changed the glow plugs
    Nov 2009
    newcastle upon tyne
    I know its not my EGR valve because ive already had this problem b4 and sorted it out,hope someone else has any ideas regarding the 'spanner'.Since its been on will it have stoed the fault code so i can get it checked out?
    Nov 2009
    newcastle upon tyne
    Sorry its a 1.9cdti 150 on a 06 plate....How much did that cost then husky and is it a simple job to do?
    Jan 2010
    Lisburn
    I got quoted £10 + vat per plug, their easy to replace, just fiddly to remove the plastic covers on them. All you need is an extended socket set and patience.
    although on the egr valve front, I thought I had mine sorted when i cleaned it and took out the solinoid etc, seems im personally having the same trouble, not sure but I think i need to replace mine, dodgy starting again (cleaned 2 weeks ago n was perfect then)
    Nov 2009
    newcastle upon tyne
    From what i read on here it seems like it is my glowplugs,my start up slow but nothing major and it is nothing like when my EGR vavle was dirty.When EGR was sticking the car was sluggish this isnt the fault i have now.Just debating on doing this myself,im thinking its just like changing spark plugs on a petrol engine?Which ive done in the past without any problems.BTW where are the glowplugs?
    Jan 2010
    Lisburn
    I was in the same boat a few weeks ago, I had done spark plugs and not glow plugs, its exactly the same.
    If you take the cover off the engine, the first 4 plugs you see are the injectors, above that is a long bar, further up but parallel there are the 4 heaterplugs attached by a cable, they sit a bit deeper into the engine. just unplug the plastic covers, they are v fiddly, i used a screw driver to carefully prise the nibs apart, gently pull off the cable connected to the plugs then, unscrew... some recommend oil/warm engine prior as to not damage the plugs on removal.
    It can all be done by hand, no fancy tools needed except a socket set
  1. Spanner Light Cold Start
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 17th April 2011, 13:00
  2. Is it possible to turn of the cold weather warning
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 11:48
  3. Car spanner light on cold start
    By gman999 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 20:18
  4. cold start only, spanner light?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 15:24
  5. 54 reg 2.0 dti spanner light on cold start
    By StephNET in forum Engine & Drivetrain
    Last Post: 8th January 2008, 22:04
vectra c spanner lights goes off after warm www.vectra-c.com
cold car spanner light
car with spanner light cold
vectra c 2.0 diesel glow plug change tools needed site:www.vectra-c.com
