Thread: alternator on way out?
    Regular Member ladyvec's Avatar
    Nov 2010
    Merseyside
    Default alternator on way out?
    The other day a friend of a friend was sitting in my car with the engine running and the courtesy light on, and he told me my alternator was on it's way out as when he turned the steering wheel the light went slightly dimmer.
    Is this right and is this car gonna cost me more money or is it a load of bs?
    Regular Member Dazzy2006's Avatar
    Notts
    ignore your freind,its normal - you have electronic power steering and it takes alot of power when in use
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    yep - totally normal.
    I thought mine was failing when I bought the car and noticed the dimming when turning while engine idles.
    PAS is electo-hydraulic and draws a large current which is most noticeable at idle when the alternator is not producing quite as much current as when you travel normally.
    Also when you travel you don't tend to turn the wheel so hard as say when you are parking, so the PAS works less, and dimming is not noticeable once you are on the move.
    Nov 2010
    Merseyside
    Ah ok thanks. I did think it was rubbish tbh.
    Ta
    belgium
    you can check it with a multi meter on your battery terminals with engine running evrything above or around 13 v is ok the older cars are around 14v but when ive got mine vec it was 13.2v and before you ask it had 55000 km on it grts,d
    Regular Member 111's Avatar
    Stockton-on-Tees
    I have posted on this matter else where, My question is will a voltage stabaliser/capacitor unit such as this help as it is really annoying??
    http://www.extremestyling.com/Green-...ource=GB&id=uk
  1. New Alternator
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 00:50
  2. which alternator
    By john1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2011, 13:32
  3. Alternator
    By m8wos in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  4. what alternator do i need?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:50
  5. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
