Results 1 to 3 of 3
Thread: strange feeling..
    Glasgow
    Default strange feeling..
    well guys their seems to be a strange kinda of feeling thru the steering, feels like a slight knocking and you can hear it kinda thru the steering.
    its very hard to describe, i was first only noticable when going very slow but now i can notice it when going faster..
    one wheel on the right hand driver side i knew needed ballanced and when on the driver side it caused the steering to shake at motor way speeds, so i swapped it to the passenger side and the shake is away.
    i know this hasn't helped much but any ideas? i feel its from the driver side..
    the steering wheel is of to the right about 1 o'clock.
    Regular Member Craig1985's Avatar
    harwich essex
    Mine was loose/warn top strut bearing
    Glasgow
    well i went out in the freezinf and took of the near side wheel and sorted the abs issue and then i checked for play, very ligght left to right or up and down, but when i go to turn the wheel it feels like a little bit of play then a clunk back and forward so im thinking worm outer cv?
    then i checked the off side, it has some play left and right but little up and down, unfortunetly i forgot to check if their was play forward and back..
    so with both wheels off the ground i started the engine and put it in second and let the wheels rotate while turning the steering and i didnt hear any noise..
    this could be due to no weight or pressure on the cv? i bealive the track rod end needs replaced though as the outer tire is wearing.
    the strut bearings where changed not that long ago, i dont have any spring sheeths but i doubt thats the problem.
    any ideas?
  1. Strange drive feeling
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2012, 17:19
  2. If your feeling a little low........
    By FIL 4822 in forum General Chat
    Last Post: 8th April 2009, 08:06
  3. feeling well pi**ed off
    By andy.l in forum The 'Off Topic' room
    Last Post: 11th March 2008, 03:20
  4. Feeling Old!!!
    By Caterman in forum Comedy & Humour
    Last Post: 8th February 2007, 12:54
