Results 1 to 10 of 13
Thread: Oil Light warning came on tonight
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Oil Light warning came on tonight
    Hello all
    As the heading says my oil light came on tonight.
    My Vec is a 2006 1.8 VVT Sri Nav with 53k on the clock.
    Can someone advise me what would be the best brand and grade of oil to put in with that amount of miles on the clock. Im not worried about how many pennies it will cost when it comes to oil.
    I have access to a warm garage so an oil change would not be a problem in this weather.
    Many thanks
    EDIT : I would top it up but I have no idea what is in there at the moment. Only had the car since may this year
    Chelmsford
    Stick a litre in, check the dip-stick, if needed stick more in until it's half way between the markers...
    I've never been a person who gives a toss about the brand... If I'm doing a complete change I use a fully-synthetic, but for a top-up a part-synth will be fine.
    Regular Member kamar's Avatar
    bradford
    if u can change then do it i get my oil from dealers. 5 30 i think it was.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Before you do anything check the proper level on the dip stick after the car has sat for 20 minutes or so. You may do damage if you just pour in a litre and overfill it. Just get it from Vauxhall if you need any. 5-30 is the correct weight I think.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for the replies all.
    Im going down to the local supermarket tomorrow (short walk) and getting some top up so I can then be mobile again until I can get the 4.5 litres or so from the Stealers.
    Oh the car will be sitting for at least 10 hours now before I check levels. Thanks for the advice though. Always handy to know these things before hand.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    No worries.
    It's always possible it can be a duff sensor giving a weird reading. I've never completely trusted them. Always go on what the dip stick says seen as that can't lie.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Envy View Post
    The oil levels should be checked with the engine hot mate. Run it up to temperature, shut it off, let it sit for 5 mins and then check it
    Nov 2009
    Leeds
    If I check my oil about half an hour after switching off the car, it sits at about 4.5/5 notches on the dipstick. If I leave it overnight, it goes past maximum on the dipstick by a few mm. Does this sound ok or have I overfilled it? I have a 2.0 DTi so I don't think it is good to have it overfilled.
    If I need to remove a little oil, what is is the easiest way to do this? I would only need to remove 100-200 mil at most
    Isn't there a sticker under the bonnet that tells you to do it when the cars warm but been stopped for a few minuites?
    Nov 2009
    Leeds
    Not that I've noticed...but I haven't specifically looked for one. Will do when I'm back at the car.
    However, I guess that means the oil level is ok! It's about 4/5 notches five mins after stopping, raises into the final notch about half an hour after stopping and only goes over max when left over night.
  1. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  2. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  3. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  4. I can’t believe how light it is tonight
    By Swatty in forum General Chat
    Last Post: 10th July 2007, 08:14
  5. Spanner light came on tonight
    By Doug-SRidirect in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2005, 23:59
