Results 1 to 10 of 11
Thread: CDTI poor start & wont rev for a couple of mins?
    Dec 2010
    Nottingham
    Default CDTI poor start & wont rev for a couple of mins?
    Hi all & hope you can Help!
    Over the last couple of days the old girl has become hard to start & once it does start it wont rev like its in limp home mode but worse!
    after a few minutes it begins to rev a little & then gets back to normal!
    Tonight it was a pig to start but after a few minutes got back to normal, after it warmed up i stopped at the offey & when i started it again it was the same not revving for a few minutes so it would appear its not temperature related!
    Any suggestions?
    Regards Sandy
    Feb 2007
    North west
    im afraid thats the EGR valve mate. Exactly what mine did. It gets much worse if you dont clean it soon.
    Dec 2010
    Nottingham
    Cheers mate!
    Is it much of a job to clean?
    Dec 2010
    OXFORD
    Quote Originally Posted by sandman1001 View Post
    Cheers mate!
    its an easy job to strip and clean an egr valve,have a look in the how to section on this forum and it clearly tells yo how to do it, do your boost sensor while you are at it.
    chris
    Regular Member kamar's Avatar
    bradford
    check injector plug, and also glow plugs
    Dec 2010
    Nottingham
    I dont think its the glow plugs at fault as i get the problem if its hot or cold!
    I picked up some carb cleaner today so the egr & boost sensor are gonna get it in the morning!!!
    Dec 2010
    Nottingham
    Well this morning I cleaned out the EGR with carb cleaner, compressed air & a small screw driver for the hard bits.
    I also cleaned out the boost sensor which was full of crud!
    Took it out for a spin & seemed much better, stopped for fuel & as I left the filling station it did the same thing!
    parked it up when i got home & tried it an hour later & it would not rev & running rough!, popped the bonnet & gave the EGR a tap with a screw driver & it smoothed out & revved as it should so I guess it,s the EGR at fault!
    Has any one taken one apart to clean out the solenoid?
    also noticed that the actuator bar for the valves in the inlet maifold is flapping about & off most of the actuators!
    what difference do those valves make to the general running?
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    EGR's can be cleaned but will go again in a few months, know this through personal experience with trying to recondition them
    Regular Member badback's Avatar
    Runcorn
    None whatsoever to mine, my swirl bar has been off for approx 30,000 miles and the car runs exactly the same. So I'm leaving it as it is unless a problem occurs.
    Dec 2010
    Nottingham
    Hi all
    The old girl failed to start this morning!!!!!
    Had to get the start N charge out to get it going plus a good bang on the EGR to get it to close!
    Tonight i have fabricated an EGR blank plate out of 1mm ally plate that fits between the EGR & the manifold to see if it sorts the starting issue & if so it will be a new EGR over xmas!
    The spanner light has come on, is this normal?
    also after the starting issue this morning the digital radio has stopped working! the CD is still working though
    Any suggetions as no DAB is driving me up the wall!!
  1. 3.0 cdti wont start
    By Evilyoda in forum Vectra C / Signum Troubleshooting
    Last Post: 7th December 2011, 19:09
  2. CDTI Engine wont start
    By dag1 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 20:11
  3. 1.9 cdti poor start...!!!
    By rioni in forum Engine & Drivetrain
    Last Post: 26th March 2010, 21:24
  4. car wont start and poor running help pls
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 21:16
  5. Signum 3.0 cdti wont start
    By Gumball 3000 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 20:06
