Anyone else getting this when trying to sign in ?
Its f*cking doing my head in !!!!
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
just found this on googleadd me brettrs
Have a look here:
PS3 Network Error Codes
Says to reboot your PS3 and router.
Gazza4
Yeah did all that, still doing it !!
Have you tried connecting your PS3 via Ethernet cable? (I assume you are currently connected via Wi-fi).
Also as you are online I assume the modem/router is fine so possibly the PS3 has a faulty LAN/WAN Card or the Wifi part has developed a fault.
Gazza4
Sorted mate, I missed the bit " Make a new connection "
