Thread: I have to de-ice the inside!
    Sep 2010
    Rushden
    Default I have to de-ice the inside!
    When the temperature outside drops below -2c my window screen ices over on the inside, which is tricky to de-ice.
    does anyone have any sugguestions to why this happens and how it can be resolved?
    Any help would be much appreciated.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    id like to know this aswell as mine does it!! when its defrosted i keep putting the wiper on thinking its the outside
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    All cars do it when its cold (double glazed ones might not)! The only way to stop it is to buy a garage!!
    Dec 2010
    Bristol
    i dont have this trouble on mine but did on my audi a3, and that was due to poor seals around the door letting in a draft to condensate on the glass,
    try and check all the seals around windows doors and boot etc, this is probably why
    Full Member
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Quote Originally Posted by s_zigmond View Post
    Mine doesn't - you must have some dampness inside the cabin which is condensing on the screen. Check for damp carpets - difficult when you tread snow into the car, and signs of leaks. Even damaged or perished door membranes can let water in.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Quote Originally Posted by vxvirgin View Post
    None of the 3 Vectra 'C's I have had have either. Used to happen on an old Fiat I once had, but I suspect that was down to Fiat build quality.
    Either damp or cold air is getting in where it shouldn't. Maybe check the pollen filter and drain under the windscreen. They can harbour damp if blocked.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Its worse when I havent been using the aircon to be honest! Presuably this explains why. Car is completely dry inside
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    I think I read on here recently someone saying you should leave the car door open for a minute or so when you switch off, so all the warm air inside escapes and doesn't have a chance to condense when left to cool overnight, and obviously freeze.
    Seems to make sense, I've not needed to try it however.
  1. inside led help
    By 0114NIGEL0114 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2012, 07:57
  2. wet inside
    By chrisg in forum Bodywork & Interior
    Last Post: 7th January 2011, 23:51
  3. Inside
    By savage. in forum Styling
    Last Post: 15th June 2009, 00:17
  4. New look inside
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2006, 18:41
