Thread: Dreaded spanner light
    carlisle
    Default Dreaded spanner light
    Last week after the car 1.9 cdti 150, had been standing for a week and abit started her up for the first time. No spanner light, and sat and defrosted for 15 mins or so, pulled out the street and drove a hundred yards and the spanner light came on arranged to go to the garage which is 20 miles away and half way there the light went off, they plugged her in an there are no fault codes stored. Car has been running fine however tonight after work defrosted the car and the same thing pull away and after 100 yards spanner light again!!! Anyone any ideas???
    Nov 2009
    Bradford
    I had the spanner light on with no running problems a few times and then intermittent running problems. So far cleaned and blank EGR and still doing the same so I will keep looking for solution.
    Mine is in constant use so not sure if it's the same problem.
    carlisle
    Just been to the garage and the code coming up is for the egr valve, they have looked in the inlet manifold and it's abit coked up. It's booked in new years eve to change it. Hope it sorts it out, this will be the second egr it's had in it's lifetime
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Make sure they do a software upgrade. There is one availableand I believe it can improve the response.
    Gazza4
  1. The Dreaded Spanner Light
    By alhambra in forum Engine & Drivetrain
    Last Post: 13th November 2011, 11:31
  2. Dreaded spanner light
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 00:58
  3. The dreaded spanner light :-(
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2008, 21:00
  4. dreaded spanner light when accelerating
    By formby in forum Engine & Drivetrain
    Last Post: 6th May 2008, 22:21
  5. The dreaded spanner light
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 21:04
