Thread: 12 wire
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default 12 wire
    would this type of connector do for tapping into the ciggy lighter wire. http://www.youtube.com/watch?v=0sGbE...eature=related
    Shropshire
    I just used one of these - http://www.maplin.co.uk/Module.aspx?ModuleNo=43076
    Similar, but easier.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    i thought the t-tap connector would be easy to remove the connecting wire when removing the headunit, the wire i will be connecting is coming from the wiring loom
    Shropshire
    Sorry - not the best with electrics! I tapped into it for an IO Play kit, as it needed switchable live. When time comes for the car to go, I can just snip the wire and insulate it.
    If you want a removable option, the tap you linked to is probably a better bet.
  1. What wire do I cut lol
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 09:01
  2. Which Wire ?
    By Ste in forum The 'Off Topic' room
    Last Post: 9th September 2012, 22:24
  3. Is this an ABS Wire?
    By asgharuk in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 19:32
  4. tel mute wire
    By jonesyboy in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2009, 22:33
  5. can you wire in an amp into....
    By jamesy in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2007, 18:23
