I am thinking to change to LED bulbs in my fog lights (vectra 07) But I am not sure if its HB4 bulbs or 9005? Someone knows? And whats the differents of those?
ket
ket
Are they not H3 bulbs, the ones with the small wire on the end of them?
No, its HB4 og HB3, the one with the "base" on the back to plug the contact. Every place I read it said H3. But its not. Its a OPC line (XP in UK). Is it special fog lights on this?
normal bulb should be H3, led bulbs don't tend to do well on the Vec.
It looks like this. But HB3 and HB4 looks the same. I think LED will be nice for daytime use.
im sure fitting LEDs will also bring the check warning on telling you that you have a bulb out
Is the check control conected to fog light also?
Ok. Thanks. I will check for some bright halogen bulbs then.
But I still need to know if its HB3 or Hb4![]()
