Thread: Will 245 40 18 tyres fit?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Will 245 40 18 tyres fit?
    As above. I presume these will be fine on my standard elite? What if it was lowered by 30mm woul dthis still be ok?
    I know about speedo issues etc
    Or should I just stick with 235 40 18?
    The rim width im considering is 8j and the offset 42 if this makes a difference?
    Thank you in advance
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    i think signumboy has 245s on his 20inch rims.. send him a pm
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Will do,
    Dec 2010
    north west
    Im on 235's on 17" rims theres loads of room to go wider
    liverpool
    will fit fine
    am on 245 35, ET 35
    EVERYWHERE
    As a guide, and if we consider 215/50/17 to be the standard tyre size, the recommended 225/45/17 is the tyre with the least overall circumference and radius. It's about 2% less than the 215/50/17 (which is why it looks smaller in the wheel arch), which means that for every 100 revolutions of the 215/50/17 the 225/45/17 has to revolve twice more over the same distance.
    Conversely the recommended 225/45/18 are 2% larger, overall, than the 215/50/17s and therefore revolve only 98 times compared to the 215/50/17s 100 revolutions in the same distance covered.
    The recommended 235/35/19s are about the same spec size-wise as the 215/50/17s.
    Anything above or below these specs will have too much of an effect on the speedo reading.
    Here's a good tool for checking correct tyre specs> http://www.miata.net/garage/tirecalc.html
    EVERYWHERE
    Quote Originally Posted by lazy_arse_pie View Post
    will fit fine
    am on 245 35, ET 35
    Are those 245/35/20s ?
    I'm presuming that you've had your speedo recalibrated?!
    Those will under-read by nearly 4mph, compared to 215/50/17s, at 70mph, and that's not including the usual over-optimism of VX speedos!
    I wouldn't want to be chancing the '77mph' absolute maximum on those!
    Nice wheels though.
  3. More tyres....!
will 245 45 19 tyres fit on vectra c
signum with 245 tyres
