Results 1 to 10 of 13
Thread: cdti buying advice?
    Derby
    Default cdti buying advice?
    Hi all,
    Going to look at a 2005 vectra cdti Sri 150 at the weekend, and just wondering if there are any common problems I should be looking for (and how to spot them!). I seem to remember something about 'swirl pots', but to be honest don't know what they are or what I'd be looking for. Any advice greatfully received. Many thanks.
    Regular Member Grimy's Avatar
    Best advice...Dont buy one! stick to a petrol, it will cost you less in the long run.
    durham
    Trim : Leather
    Quote Originally Posted by Grimy View Post
    Maybe a bit of good advice there! I do love the way diesels drive especially the v6 but am dreading anything going wrong with her as they say they are expensive to fix. Diesel used to be cheap once over not now!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by Darren Derby View Post
    Hi all,
    allow aprox 2k for any repairs that are needed .....
    Oct 2007
    Ripon
    I own one ..... I wouldn't get another older one, half of it newer than when I bought it!
    Maybe one of the later ones if the price was right .... But I'd still have a reserve pot for things like the DMF etc.
    Shame because when it is running I love it.
    Derby
    Ahh, not quite the advice I was expecting. Well, that's me thoroughly put off! My other thought was to spend more and get an Insignia SRI, although again I'd be looking at diesel. Hopefully the newer design would be more reliable?!
    Sodding Typical on Sea
    The 1.9 CDTI has four basic issues pre 2007 the injector wiring loom there is a very cheap fix for that, a couple of quid will fix that. The inlet manifold swirl flaps lever fails, and forces a replacement manifold, this is not different to most common rail diesel engines (Merc and BMW are just as prone) Allow about £200 plus fitting as an average
    Next we have the EGR valve which is a £100 replacement or a freebie clean up grease and replace.
    Final one is again very common to every new gen diesel that is the dual mass flywheel clutch and slave. This is a biggie and can run about £1000 but many have had theirs done for about £600 all in ans some do it themselves for about £400.
    Do NOT be put off the car as they are lovely to drive and very reliable when looked after,so if you want the car, get a warranty! simples
    Oct 2007
    Ripon
    Darren,
    Luck of the draw with them ..... Have a look around some have run like a dream for thousands of miles, however the common faults are expensive, if the car you have been looking at has had the work ..... Maybe worth it?
    Def check on inlet manifold, clutch dmf and give it a good run looking for judders from engine and knocks from bushes and springs ...... What I can think of to look more in depth at on the cdti apart from the norms.
    Regular Member Mick B's Avatar
    North East
    my Cdti V6 runs like a dream.Its a very responsive car and get 40+ to the gallon,not bad for a 3.0 V6. As with any modern car if they fail they can cost money its not just Vectras.Make sure you get one that has a good history, lowest miles and owners possible.
    Jan 2010
    devon
    Go for it mate..the 1.9cdti is as reliable as any other car out there..the forums are here for peoople with interest in the car's and also alot of people asking for advise with problems..look at the bmw/audi/merc's/fords/ etc etc forums,there full of problems also,thats what there here for.And also look at why company's buy them for fleet vehicles,there mile munchers with low cost problems,why else would they buy them if they cost them a fortune to maintain..There is always a risk that you buy a lemon as with any car..good luck,but i recommend the 1.9cdti 07 plate onwards as i have one with no probs so far..TOUCH WOOD lol.
  1. CDTi - Buying Advice
    By welshhuw in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2012, 19:27
  2. Signum 3.0 CDTI buying advice
    By g1jkb in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 22:19
  3. Buying Advice - 3.0 cdti Pre-Face Signum
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2008, 17:31
  4. Vectra 1.9 CDTi buying advice..
    By Faz in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2007, 01:07
  5. Looking at buying a 3.0V6 CDTi:Advice please!!!
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2006, 18:43
