Thread: Safe
    Nov 2010
    Default Safe
    Hi, I have just fitted a new thermostat on my 1.9cdti. Whilst doing so I took the opportunity to decoke the throttle body, egr and boost sensor. When I started it up it fired up first time and is a lot more responsive and feels a lot smoother to drive. I'm happy with it.
    However the word safe has poped up on the dash.
    Does this mean it is in safe/limp home mode?
    The car drives really well, I suspect it is not in limp home mode but could be something else.
    Will it "learn" and reset itself or is it Opcom time?
    Any ideas welcome
    Mike
    Jul 2009
    The Rift, Cardiff
    Safe is displayed when the radio code is required, usually due to power loss ie disconnecting the battery.
    The code can be found on the CarPass if you have one, if not its £20 from the stealers.
    AFAIK the car will will learn and adapt to the changes.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    SAFE is purely for the radio code to be re-keyed in.
    As said above, this will be on the red and white audio / security pass (cardboard credit card type thing)
    Just look in your audio manual for key code inputting procedure...
    any engine problems will be denoted by the engine symbol staying lit-up on the dash more than say 10 seconds after starting up...
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    In answer to this, when doing Mike's Temperature Sensor,
    It was noted that the SAFE issue has been sorted.
    However it is believed that the radio CDR2005 and screen have a different code to the Car, as it was not possible to enable his fog-lights.. (Pass Code Not accepted)
  1. CDC40 DAB safe
    By Neil71 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2016, 12:51
  2. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  3. Display safe
    By ServerKing in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 06:05
  4. Is it okay to / safe to
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2006, 11:15
