Thread: Nose from 6th gear 2.2 sri direct
    Aug 2009
    EastKilbride
    Default Nose from 6th gear 2.2 sri direct
    hi guys wonder if yous could help. My dad owns a Vectra 2.2 sri direct 55 plate. Its done 40,000miles and has developed a whine from 6th gear. It only happens while in 6th gear though. I have advised maybe a gearbox oil change might make a world of difference. Does anyone know if this is a common fault if if anyone has had the same problem? any help would be much appreciated thanks!
    Steven
    Aug 2009
    EastKilbride
    meant to say "noise" in title, sorry folks.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    sounds like gearbox bearings or diff bearings starting to go is common on m32 boxes..
    6th gear? I never realised the 2.2 direct had a six speed box.
    Aug 2009
    EastKilbride
    is that common paul? cheers for your reply! old mans kinda worried if that will be covered under warranty! (arnold clark warrant) cheers mate!
    rapala yeah they have 6 speed box's i have driven one that also has a 6speed!
    Oct 2007
    estonia
    If it is M32 6speed box then the bearing fault is quite common. Also applies to 1,3 diesel/1,6turbo M20 6speed box. If you have whining noise only with 6-th speed then you might get away with only 3 new bearings (all located inside box`s cover). If you replace the bearings please also check if the shafts inside the box are running freely with the new bearings. If not thenyou have to replace also the shims under bearings to get more clearence. Otherwise the box will fail again soon....
  1. nose to nose facelift towered!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 09:59
  2. noisy 6th gear on a 56 plate 2.2i direct
    By alanatrr in forum Engine & Drivetrain
    Last Post: 19th March 2011, 18:14
  3. My nose job ...
    By hans_vledder in forum Styling
    Last Post: 27th January 2008, 17:48
  4. Red Nose Day
    By leeandjude in forum General Chat
    Last Post: 17th March 2007, 11:47
  5. 2.2 Direct SRi gear ratios
    By bertxuk in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2006, 12:39
