Results 1 to 10 of 11
Thread: vectra 2.2 dti owners and vari vane turbo
    midlands
    Default vectra 2.2 dti owners and vari vane turbo
    my vectra 2.2 dti drives ok but when it hits 3000 revs it struggles to go through the rev range, getting to 4000 revs can take nearly 10 seconds from 3000 revs on, im sure this is not normal
    also the car picks up ok prior to this but at no time do i get a hit from the turbo, being vari vane turbos should i feel it kicking in higher up the rev range
    myn is the vec b but i assume they have the same tuebo and engine
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Same engine and turbo. Yes should pull effortlessly all the way to the red line.
    Suspect you have a hole in your turbo pipes somewhere. This is a common prob on these engines.
    Do a search for turbo boost hoses.
    Regular Member Dazzy2006's Avatar
    Notts
    - You should definately feel it when the turbo kicks in
    As graham suggested check your boost pipes aren't split, might also be worth checking the boost sensor and egr aren't clogged up
    midlands
    egr i have cleaned as well as the boost sensor, i have a front mount intercooler and the pipes going to the inlet are alloy and samco which i know are fine, the pipe coming of the turbo is metal, so the only pipe remaining is the final rubber hose to intercooler and im sure its fine but will have a look
    also if there was a hole wouldnt the car produce black smoke from the exhaust and maybe engine management light
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If there was a hole in the intercooler hose the car would produce massive amount of black smoke and eventually kick into limp mode(management light). When was it last serviced? Give the mass air flow sensor a squirt of brake cleaner...worked wonders on my old 3.0. It then worked just enough so I could diagnose it was faulty. Give it a try
    midlands
    car is serviced regularly every 3k with diesel oil and air filters.the air flow meter isnt even a year old, wouldnt putting carb cleaner on it damage it
    there are also no management lights coming on
    midlands
    normally gives me 34 mpg in the city and 50 mpg motorway only gave me 27 mpg todays in the city, all ihave done is vent the cranck fumes to atmosphere, surley this wouldnt cause problems to mpg
    other possibility is air flow meter but i have no engine management light coming on
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Thought it was only the CDTI's that have variable-vane turbos.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Nope the 2.2dti has them too, the 2.0 doesn't though
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Thanks John. I knew the 2.0DTI didn't, just thought the 2.2 didn't either.
  1. 2.0 turbo owners..
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2012, 21:25
  2. All 2.0 turbo owners
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2011, 22:17
  3. vectra 2.2 dti owners and vari vane turbo
    By turbo diesel in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 14:41
  4. Vectra SRI Turbo Owners?
    By ropa83 in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2009, 19:32
  5. 2.0 Turbo owners ONLY!!
    By The-Bandit in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2008, 22:15
turbo boost 2.2dti
