Results 1 to 2 of 2
Thread: Clutch Switch wiring?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Clutch Switch wiring?
    Hey guys, as some of you know ive had issues with my CC and ive gotten it down to the clutch switch.
    Turns out i don't actually have one, and this is why when the CC was working and i depressed the clutch the car would rev out.
    After buying a new switch and going to install it i have noticed that there are two wires (pale blue and black) which have been cut above the clutch pedal and joined by a block connector. What i THINK has happened is that this has been the connection to the switch and somebody has simply eliminated it.
    can anyone confirm these are indeed the correct wires?
    If so, where would i get a new connector suitable to match the switch (2 pin)?
    Nov 2010
    UK
    I've just had another thought - Does the clutch switch when depressed break the circuit and cuts the CC in this way? So if the wires are joined permanently then the clutch shouldn't be causing me problems anyway?
  1. t/c switch wiring
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2013, 12:16
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. Wiring up the TC switch
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 20:07
  4. Ignition switch wiring please!
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2008, 00:05
  5. Need help on wiring a Kill switch
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 08:30
vecgra c clutch switch
