Results 1 to 10 of 19
Thread: Is there a how 2
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default Is there a how 2
    for putting in a auto dimming mirror?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Full Member
    South West
    There was one written using a non loom wiring method i think, but if you are planning on installing one with the proper loom, then this is what you need to do:
    Plug loom into rear fuse box
    Run loom under roof lining
    Plug loom into mirror
    Fit Mirror
    It really is as easy as that mate....
    I am inept when it comes to cars, but even i managed this one!!
    Rgds
    Aidi
    Are you VXR Enough
    13 Post(s)
    pity you aint closer you could help lol
    Are you VXR Enough
    13 Post(s)
    i went to the scrap yard today and got the mirror and the ribbon which took ages to carefully strip out for a grand sum of £5 lol bargain
    just not too sure how it all wires in
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The how2 in the how2 section does indeed use the correct loom/ribbon cable. Even taking your time it only takes about 30 mins.
    Wales, UK
    I got mine off ebay, member on here too.
    Easy to do, the hardest part was routing the ribbon cable. A well recommended mod by me, if not just for the ambient night light thing. lol
    Full Member
    South West
    I think the trick with roof lining is be firm but not heavy handed. Its quite flexible if you do it bit by bit. If you are forcing it you are probably doing it wrong.
    Only hard part i found was getting it in where the door pillar is, but a bit of perserverance and it went in.
    Oh, and most importantly of all... make sure you have clean hands! Mucky marks on a headliner is ugly to say the least!
    Rgds
    Aidi
    Are you VXR Enough
    13 Post(s)
    is there a plastic cover that goes around the base of the mirror
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    This is interesting Chris - I fancy this too on our C (and on my B infact)
    We can hack your car up together to try - and then do mine once we know what we are doing
