Thread: BG 244 - Anyone used this?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default BG 244 - Anyone used this?
    http://www.powerenhancer.co.uk/news/...for-diesel/33/
    Saw a guy on another forum saying how he tried this thinking it won't work, but found his car running far better within 50miles.
    Has anyone used this treatment and is it safe with a DTi fuel pump??
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Seems like some good stuff tha. i would try but like you say will it be ok with the pump
    Nottinghamshire
    A good cleanout is good, but personally I would check that it lubricates the pump as well to help compensate for the low sulphur content of modern diesel fuel.
    I went for Wynns Professional Diesel System Cleaner because it cleaned and lubricated.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Alot of people are adding 2 stroke to diesel to help lubricate the pump etc
    Apr 2009
    Stevenage, Herts
    Default Reply from "powerenhancer"
    Bit of an update, I finally got round to contacting them, this is what I wrote and their reply - it's posted on the website;
    Hi there, heard good things from car forums Iím signed up to, will the BG244 be ok in a 2002 Vectra 2.2DTi? I only ask as the fuel pump uses the diesel to lubricate itself so any cleaner which hasnít got a lubricant in is a no no so Iím told.
    Many thanks
    Simon
    Hi Simon, That advice is incorrect. High pressure diesel pumps rely on the lubricity additves in pump fuel to help protect the unit. BG244 contains additives to clean AND lubricate the pump, more so than with conventional pump fuel. Additional lubricity is a good thing.
    Best regards, PE Team
    Comment by Simon ó January 10, 2011 @ 5:58 pm
    Aug 2010
    Stoke on Trent
    Hmmm... thing is... the guy is selling the stuff so he's bound squash your concerns to get a sale in the current economic climate especially since it would be nigh on impossible for you to attribute any fuel pump failure down to using his product...
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Worth keeping an eye on, I already use redex regularly and V power fuel when I can.
    Jul 2009
    Brighton
    Default Bg244
    I've just put a can of the stuff in mine (CDTi 150), so will wait and see what falls off
    I've read good comments from the states, where it's been available for ages.
    I've been regularly using BP fuel with Millers, but this stuff is meant as a yearly 'clear out'!
    I'll let you all know in a weeks time.
    Jul 2009
    Brighton
    Default Bg244
    275 miles on and the car feels more responsive. MPG is better, but not by much, although hard to tell when the DPF does a regen!
    Would I recommend it? As a preventative measure, yes, especially with the renowned soot build up on the CDTi.
    It's once a year, so build it into your service.
