Thread: Z19dth thermostat
    Sep 2010
    Netherlands
    Question Z19dth thermostat
    Hello,
    Today my service light is coming up and my car switch to emergency modus.
    I checked with opcom the warnings and i don't see any strange things (i don't switch the contact to off).
    So i switch the contact off without resetting the faults and back on.
    The service light was coming up and going off and the car runs normal?
    Very strange... Because i don't see a warning with opcom?
    But what i see i came back from work and i see the temperature was going to 60g/celcuis. After a while it going back to zero and the service light was coming up.
    At home i started the car again and drive +- 1 km and the temperature is going to a normal level (in some seconds).
    So my question, i think i have a problem with my thermostat?
    But is it normal that the car is going into a emergency modus?
    Thank you.
    Nov 2010
    luton
    hello, ive just replaced my thermostat today after the temp gauge showing cold for about a month, never had any spanner lights or service lights or the car going into emergency mode, sounds a bit more serious than the thermostat
    would recommend putting it on a computer mate
    Sep 2010
    Netherlands
    Thanks for you reply.
    But when you compare the temp before and after the replacement of the thermostat what are you seeing?
    Nov 2010
    luton
    hello mate, merry xmas
    before, the needle was exactly on the cold mark, it would move very very slightly above the C.
    once change, after about 2 miles it went straight to 85c
    Full Member Big Sig's Avatar
    Quote Originally Posted by genesisfm View Post
    Hello,
    The service light won't put your car into limp home mode. if its saying insp or a car with an oil can its just due a service, if its a car with a spanner its displaying its got an active fault.
    Just to try to clear things up
    Sep 2010
    Netherlands
    Thanks!
    Merry xmas
    After 50km my car temp. is max 80 celcius.
    When i drive 20 km it's around the 70 celcius.
    I think i have to replace my thermostat.
  1. thermostat for z19dth , a wee question
    By simplesi in forum Engine & Drivetrain
    Last Post: 18th October 2012, 01:19
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  4. Z19DTH Thermostat
    By iRocco in forum Engine & Drivetrain
    Last Post: 20th April 2010, 10:30
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
