Thread: Tools required for 2.0DTI Plug Change?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Tools required for 2.0DTI Plug Change?
    more specifically i'm wondering what size socket i need for the glow plugs to remove them, however having only done this job once on an escort i'd like any advice i can get as it was a pair last time!
    I understand vauxhall glow plugs have a knack for snapping so i'll use a generous amount of plus gas before getting them out and warm the engine, and i'll copper grease the new ones.
    Thom
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Tooling wise i used 10mm long reach socket a foot long extension bar and a ratchet , for the ratchet i used the smallest one i had so as not to put to excessive load on the g p
    also best to remove the engine cover and turbo return pipe on top of manifold .
    In addition its best to warm the engine up as well before starting,
    note you can only use the extension bar on three of the g p,s the fourth one under the turbo pipe can be done just by going direct with socket and ratchet.
    and still loving it
    Nov 2010
    UK
    cheers mate, so a deep 10mm socket and extension bar - got it.
    Sounds straight forward, touch wood!
    Regular Member Dazzy2006's Avatar
    Notts
    as above 10mm socket - i would use the plusgas for a few days beforehand and on the day your going to change the glowplugs get the engine HOT.
    If they wont budge leave them as i snapped 1 last week and to get it fixed is going to cost £750
    Regular Member ladyvec's Avatar
    Nov 2010
    Merseyside
    Im having a problem with mine at the minute, 3 are changed, I just need to get a knuckle (I think!?) for the last one as we cant get to it.
    Notts
    Quote Originally Posted by ladyvec View Post
    If its the plug under the turbo intercooler pipe - its easier to undo the pipe and move it out the way
    Nottinghamshire
    Quote Originally Posted by Dazzy2006 View Post
    That's what I did. Also taking off the heatshield over the turbo (3 bolts) gives you quite a bit more room as does loosening the plastic cable guide that the glowplug cables come out of (remove the bolts and it can move about quite a bit).
    As above though, the main tools you need are preparation, care, and patience.
    Nov 2010
    Merseyside
    Yeah, we moved the intercooler pipe (I say we, I mean my Dad) but the tool he had wouldnt reach, he said it needs an extension or a knuckle or something (my knowledge of these things is as minimal as anything)
  1. Anyone in southeast with the tools to change wheel hub
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2013, 16:44
  2. Tools required for oil & filter change
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:15
  3. could someone confirm oil change tools 3.2
    By TimTay in forum Engine & Drivetrain
    Last Post: 11th August 2011, 15:59
  4. Rear shocks - tools required???
    By mr.c72 in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2010, 13:50
  5. What tools will I need to change brake pads
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2008, 20:30
