Thread: Few questions
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Default Few questions
    Can anyone help with the below questions. Searched but cant find the answers :-(
    1 - How do i remove the ciggy lighter to replace the bulb. Cant get the thing out. Ashtray comes out but cant get rest out.
    2 - My car comes with no mirror in the drivers side. Can i swap out the visor for one with the mirror as cant see the power connectors in my car. Presume they are hidden in the roof liner ?
    3 - Where is the coolant temprature sensor in the engine. My temp never seems to move. Only now and then it lifts over the first mark so was thinking i need to replace to sensor.
    Cars a 55 plate cdti 150.
    Liverpool
    No one able to help ?
    South West
    Easiest way.. Remove the surround which goes over the gear stick, remove the ashtray holder, you should have access to the cig lighter at that point. Again, give it a tug and it will come out.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sunvisors can be changed easy enough check eBay
    Irmscher Insignia CDTI 130
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    QUOTE
    "3 - Where is the coolant temprature sensor in the engine. My temp never seems to move. Only now and then it lifts over the first mark so was thinking i need to replace to sensor."
    I saw a post on here (try a search) about testing the guage by connecting lead to earth.
    Thermostat failing (they fail open) would sound more of a cause for you low temp guage. How is the heater - if not roasting then this is likely your problem
    Quote Originally Posted by Gavin2.6 View Post
    A : with great difficulty to be honest most of the time you end up breaking the cig lighter , remove the ashtray and you should be able to see under the cig lighter , the bulb holder should just pull out or twist out and you should be able to do this with out removing it
    A :yes you can swith the sun visor but you may not have a harness above the headlining for it as different vehicles have different harnessed there not generic
    A : dont know location but what you describe it sounds more like a sticking thermostat
    answers above
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    sounds like another thermostat problem
  1. HID questions
    By Angel1368 in forum Styling
    Last Post: 9th May 2012, 11:08
  2. A few questions!
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2009, 21:38
  3. A few questions.......
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2007, 17:18
  4. Just a few questions ;)
    By BlueRob in forum Petrol Engine related
    Last Post: 24th July 2007, 04:30
  5. Questions !!!
    By zubs187 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 17:16
