Thread: 2.2DTi Thermostat
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default 2.2DTi Thermostat
    Chaps,
    My thermostat is kaputt - the temp doesn't move in this weather unless stuck in traffic, and athough heat comes through the vents it takes a while.
    As I'm getting rid of the car next year I don't wanna spend £60 on it, so have found one from a 2001 Zafira DTi on ebay. Can anyone tell me if this is the same unit & housing or not so will it fit?
    Also - does anyone know what other Vauxhall models have the same unit, so I can broaden my search?
    Apr 2009
    Stevenage, Herts
    I've just got the part number for mine # 24420728 - can anyone find out what else this fits??
    THanks
    Apr 2009
    Stevenage, Herts
    Ok new idea - can the thermostat be taken out the housing, and is there another thermostat that will fit in? I just begrudge paying £53 for something that's only ever cost £7.99 before! Call me tight if you like
    Nottinghamshire
    I'm sure someone posted recently that you can get a Quinton Hazell thermostat that is a push and twist replacement for the old broken one - I think you get a cardboard tube with the new thermostat to do the fitting with.
    The housing that is changed with the 'proper' part is therefore not replaced, although you may need the gasket for it as you'll still have to take the housing off.
    Nottinghamshire
    QTH595K (opens at 92 degrees) on page 110 here.
    Some for sale here.
    Which means you can get the full proper thing cheaper (if this is the right one for your car) unless you can find the QH part cheaper somewhere.
    Check dealers as well - they can be competitive especially with Trade Club .
    Apr 2009
    Stevenage, Herts
    Thanks James24, that's really helpful and useful to know! Gonna keep that QH sheet, thanks again!
    East Midlands
    All the info you require is HERE,
    Apr 2009
    Stevenage, Herts
    So sorry to go on about this, my engine is the Y22DTR, same code as the Vec B 2.2DTi - but the thermostat is coming up different. In short;
    Vec C part;
    QTH595K complete (no other option)
    Vec B part; (same engine)
    QTH573K complete or...
    OTH600K just for the spring unit itself (£9 on the net).
    ALL set for 92deg - so does anyone reckon the Vec B thermostat will fit in my housing? Again, the same engine code for the Zafira is another part number again.
    Weird huh?
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by macdad View Post
    YOU'VE just answered my prayers whilst I was figuring it all out!!! Thanks!!!
    Nottinghamshire
    Quote Originally Posted by si_hoss View Post
    Vec C part;
    Weird huh?
    I guess a quick call to QH may resolve the query? I would think that changes have been made to the engine over the years - for cost/performance - and to add new parts to the inventory for us to buy .
    If the full unit is cheaper than the QH unit (assuming the Vec B one doesn't fit), will you replace the 'stat and housing?
  1. Thermostat 2.2dti
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2012, 19:19
  2. Dti Thermostat
    By dave300776 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2012, 13:59
  3. thermostat....
    By Vectra boy in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 11:50
  4. thermostat 2.2 dti
    By tomo610 in forum Diesel Engine related
    Last Post: 9th January 2011, 22:25
  5. Thermostat stuck open - 2.2dti
    By cont1204 in forum Engine & Drivetrain
    Last Post: 25th September 2010, 21:45
