Results 1 to 10 of 16
Thread: Stiff gears.
    Regular Member ladyvec's Avatar
    Nov 2010
    Merseyside
    Default Stiff gears.
    I've noticed that when trying to go into first and second gears on my 03 Vectra, it seems very stiff. Ive got to be very heavy handed to get it into gear. It doesnt seem as bad for all other gears.
    Is this a common problem? And is there something simple I can do to help remedy is before I do damage to the ligaments in my hand (or to the gearbox)
    Regular Member Thom's Avatar
    Nov 2010
    UK
    I was just about to ask about this!
    I have a 2003 vectra dti 2.0 club and ive noticed when cold i have absolute hell on going between first and second gears for about the first 2 or 3 minutes of driving, and then sometimes its a struggle to get into gear when shifting down the box for lights etc. I think it's normalish as my fiesta and escort were both the same in low gears.
    lanark
    6 Post(s)
    Year : 2017
    is this happening all the time or just when the car is cold ?..
    Regular Member Jezzy's Avatar
    S.E
    The cold makes it worse, but changing the oil and putting in molyslip grease will help.
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    i have also noticed my 03 2.2 dti is a little stiffer changing gears when cold but only for the first few mins.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Just work it in & out or 3/4 a couple of times first!, Dont force into gear though, its something that happens when its cold & im used to it now.
    Nov 2010
    Merseyside
    Quote Originally Posted by neverlandandy View Post
    Yeah, it does seem to be a lot more so when cold, although its never perfect.
    Nov 2010
    Merseyside
    Thanks will try that.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Yep, same as my 1.8 02 "C" box stiff when cold. Try gently pushing the gear stick to the left when going between 1st and 2nd and push genlty to the right when using 3rd, 4th and 5th. I was always taught never to hold the gear stick with your hand over the top but to always have the flat of your hand either one side or the other.
    Nov 2010
    Merseyside
    Quote Originally Posted by carpet View Post
    Thats already drilled into me, although my hand is always resting on top of the gear stick, I always move it to the right to push away from me when changing to 1st or 2nd.
  1. 1.9 cdti stiff gear lever and cant select gears
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 01:40
  2. stiff gears
    By nicj in forum Engine & Drivetrain
    Last Post: 4th November 2011, 14:30
  3. Stiff gears!
    By watchman in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd January 2010, 10:37
  4. Stiff Gearbox
    By dmoffat in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2007, 22:54
  5. Stiff Doorhandle?
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2006, 02:08
https:www.vectra-c.comforumshowthread.php124573-Stiff-gears
vectra c wont go into gear
gears are stiff on vauxhall
vectra c notchy gear change
insignia tight gear stick
my insignia sri seems sticky between gears
hard shift gear cold vectra
vectra c hard selecting 2nd gear
vectra dti hard to put in gear
insignia hard shift
vectra wont go into gear
vectra c sticky gear
vectra c2.2 stiff gearbox
gears stiff vectra c
vectra gears stiff
vauxhall signun not going into second gear
vectra c auto gearbox when cold
vectra 1.9 cdti stiff gear changes when moving
vauxhall vectra gearbox hard to get gears heats up a lot
vectra c stiff gears
vectra c gearbox stiff
stiff gear stick vectra c
vectra gears
vectra gears are stiff to select
vectra c gears stiff to select
