Results 1 to 8 of 8
Thread: cam belt change.
    May 2010
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default cam belt change.
    ive just bought a 1.9 cdti sri 150 with 80,000 on the clock,i was just wondering if anybody knows when the recommended time is to change the timing belt?thanks
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Now!, inc water pump as they can seize up.. They do say 100k but better be safe than sorry,,
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    100k but I would definatly get it done now if it has defiantly not been done already. Some recon 60k max for a belt on the 1.9.
    May 2009
    Glasgow
    mine was done at 99k miles mate, gonna be done again on 180k ( if she makes it! )
    May 2010
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    thanks lads..
    Oct 2007
    Ripon
    Got mine done about 82000 ...... The mech showed me the old parts and they were close to breaking up.
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by dazza2393 View Post
    Fortunately one of the easiest to change.
    Others may not agree but it is far too easy to be a tooth out if you don't use the £40 locking tools. It goes in place nicely a tooth out. It is a bit of a struggle to get the belt on as it is very tight when correct between the crank and cam pulley.
    My old belt had paint marks (indicating locking tools were not used on it) but was still a tooth out and had been for 60k miles.
    If I had just replaced it by using the existing marks I would still be a tooth out!
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    A good tip is fit with the sealy locking kit, fit the belt to the cam, & the crank, but not the others, secure at cam & crank then pull the belt tight in the middle to remove any 'slight' movement, then fit to rest on the r/n side first.
  1. Cam belt change
    By jacko52 in forum Diesel Engine related
    Last Post: 10th January 2011, 22:01
  2. Cam belt change, do I get it done?
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2010, 13:27
  3. Cam Belt Change
    By darrenmac in forum Engine & Drivetrain
    Last Post: 17th June 2008, 20:59
  4. Cam belt change now or later
    By mr.4dil in forum Engine & Drivetrain
    Last Post: 20th February 2008, 22:57
  5. 03 1.8 sxi cam belt change
    By mickeyc in forum Engine & Drivetrain
    Last Post: 10th October 2007, 08:18
