Thread: Squeeling from engine
    Regular Member Gortreck's Avatar
    Sep 2009
    Newcastle Upon Tyne
    Default Squeeling from engine
    Hi Folks
    I had a bit of a problem this mornign and since i was running late i had to bring the wifes car to work :S
    When i started the car a squeeling noise came from under the bonnet, I dont recall this increasing in pitch with the engine revved, just the noise level. I have searched on the forum and the only thing remotely close to what it sounds like is
    http://www.vectra-c.com/forum/showth...ight=squeeling
    Is this what it is? If so, could i change itmyself and how much would it cost me to do so? I am not a mechanic, but do have good technical knowledge .....
    If i cant change it myself, how much would a garage charge to change that does anyone know?
    Thanks in advance
    Tony
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    mucker this is very easy to change ,you cant really go wrong with it,before i looked in the link you provided i thought it was the same belt (could be wrong)but even if it isnt that it is the best place to start as it is the cheapest part
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If it's just the belt then it's fairly straight forward, chances are though that the tensioner has seized (as often happens). It's only 2 bolts to remove to change it but one of them is a pain with being so close to the chassis leg.
    Sep 2009
    Newcastle Upon Tyne
    I dont suppose anyone has a bit of a step by step do they?
    Would make my life a lot easier. Also an approximation as to how much ?
    Also, if the tensioner has just stuck, would some WD40 on it help unstick it? or would that just make the belt slip more?
    Tony
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The tensioner is hydraulic so wd40 wouldn't really do much
    The belt is about 10-15 quid and the tensioner 50 odd.
    Sep 2009
    Newcastle Upon Tyne
    Ok, cheers John
    Will have a look and see what it is
    Tony
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The aux belt is worth looking at, i use rubber & nylon lubricant to make sure its the belt thats squeeling, its available from halfords.
  1. Squeeling sound :/
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 13th October 2012, 07:59
  2. Engine Squeeling when started, hot or cold
    By benparker in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 16:56
  3. degreased and presure washed engine, now squeeling aux belt
    By chucky121 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 10:20
  4. Squeeling brakes
    By sy_uk in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2010, 13:37
  5. Brakes squeeling
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2008, 00:44
