Thanks Thanks:  1
Results 1 to 10 of 15
Thread: temp gauge problems
    Dec 2010
    liverpool
    Default temp gauge problems
    I own a vectra 05 reg cdti sri 150bhp, the problem is
    1) i don't no if i have a faulty temp gauge , the gauge works but if i drive my car the needle will rise to the first mark on the gauge, but if i stop at light's the needle will drop to the zero , then same again, the heater is working fine , when the engine has warmed up the heater is blowing hot air , but the gauge is showing zero if am stop at lights,
    2) I have had a new temp sensor fitted ,because i was told this might be the problem, but no luck, been told might at to replace the clocks ,
    the water level's are all fine. hope someone can sort this problem ,thanks
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Thats a bit extreme, could be a duff thermostat. Can be changed for a few quid. Much cheaper than new clocks!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Thermostat. The hot air being blown into the cabin is drawing the hot air from the engine bay, and as the thermostat is jammed open (from your symptoms mines does the same), it will be cooling the engine down.
    Whoever the mechanic was they should have spotted that or at least have eliminated it when diagnosing.
    Gazza4
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    you need a new thermostat fella as yours as stuck open
    Regular Member 1-8clusive's Avatar
    Jun 2009
    sheffield
    Default Thermostat or guage?
    I recently had to have a new thermostat fitted (Petrol 1.8) and saw similar symptons to yours, One thing to remember even when the gauge is on the bottom the water temperature could still be 70 deg C so your heater still works but not red-hot. Can you feel the hot air in the car get any cooler as it draws the heat out of the engine? If you can feel a difference in the hot air in the car that matches the temperature gauge it will help confirm it's the termostat sticking open. It's not a big difference though with mine the heater was really hot when engine is 90deg and just nice and warm when engine was 75 deg
    16 Post(s)
    Year : 2010
    trust me fella its the thermostat
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Apr 2009
    nottingham
    definitely
    Aug 2010
    Leeds
    Quote Originally Posted by george roper View Post
    The wire from the temp sensor put this to earth with ignition on does the gauge sweep over to the hot or does it fail like it does when you drive?
    If it sweeps over and stays in hot the gauge is fine, if it judders it's faulty.
    Same way as checking fuel gauge.
    You may have a stuck thermostat but don't rule out the gauge for a simple test.
    Dec 2010
    liverpool
    thanks very much for everyones help and comments, i am gonna change the thermostat i will let everybody know if it works , george roper
  1. temp gauge
    By pipeman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 12:55
  2. temp gauge on 1.8
    By MID LIFE CRISIS in forum Engine & Drivetrain
    Last Post: 14th January 2010, 22:10
  3. temp gauge
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 15:59
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Temp Gauge
    By amiddleton in forum Petrol Engine related
    Last Post: 24th September 2008, 12:40
vauxhall vectra temperature sensor problems
vauxhall vectra 1.9 cdti temperature reading varies
vauxhall vectra 1.9 ctdi engine temperature gauge varies
vectra c temp gauge not working
vauxhall vecrra 1.9 ctdi temperature gauge reading varies
vectra c temperature gauge not working
vauxhall vectra c temperature gauge
vectra c temp gauge problems
vectra c temp sensor problems
vauxhall vectra c temperature gauge not working
water temp gauge not working vectravauxhall vetra temperature switch not workingtemperature gauge on vauxhall vectra faultywhy does my temp gauge stop working in my vectra when I use my heatersopel vectra faulty temp gauhevectra 1.9 cdti sri temperature gauge not working site:www.vectra-c.comVectra c gaugenew vauxhall cdti.temp.sensor still no gaugetemp gauge vectra c stickingvectra c temperture gague zerovectra c coolant gauge not workingvectta c faulty coolent sensorTemp gauge dont work on vectra cWhere is the temperature gauge vauxhall vectraVectra c temp gauge
